Neatly displaying strings in block diagram
Hello
So i have a string about 3 pages long, full of SQL commands. As you would imagine, this looks like **bleep** on the block diagram.
Is there any way to better display this without it taking up ungodly amount of space? I'd still like to easily view the whole string at a glance, without much scrolling or resizing the string box.
(905 Views)
You could use a Case structure, wired to a number constant, then you  split in pages and past in different cases.
(900 Views)
Something like this?  Smaller font, enable wrapping, vert scrollbar enable.  There will be some scrolling, but this string constant contains about 1650 words.
(877 Views)
Why you want to keep this in block diagram?
Create a document and link to your project files if its for documentation purpose.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(874 Views)
@AeroSoul wrote:
Hello
What is the purpose of this 3-page long string? Based on the use of this string, it must be appropriately placed/structured.
Santhosh
Soliton Technologies
(859 Views)
