Neatly displaying strings in block diagram
Hello
So i have a string about 3 pages long, full of SQL commands. As you would imagine, this looks like **bleep** on the block diagram.
Is there any way to better display this without it taking up ungodly amount of space? I'd still like to easily view the whole string at a glance, without much scrolling or resizing the string box.
(1,108 Views)
You could use a Case structure, wired to a number constant, then you  split in pages and past in different cases.
(1,103 Views)
Something like this?  Smaller font, enable wrapping, vert scrollbar enable.  There will be some scrolling, but this string constant contains about 1650 words.
(1,080 Views)
Why you want to keep this in block diagram?
Create a document and link to your project files if its for documentation purpose.
(1,077 Views)
@AeroSoul wrote:
Hello
What is the purpose of this 3-page long string? Based on the use of this string, it must be appropriately placed/structured.
Santhosh
Soliton Technologies
(1,062 Views)
