High speed data acquisition - The application is not able to keep up with the hardware acquisition.
@dubnium wrote:
You are right. But I need a high sampling rate such as 200k/s or so. That's why I use the Producer/Consumer structure, as suggested by some of the replies in this post.
The TDMS Streaming is FASTER than the Producer/Consumer because it avoids levels of overhead.
Message 11 of 15
(1,937 Views)
You are awesome.
Message 12 of 15
(1,933 Views)
Thank you very much!
Message 13 of 15
(1,931 Views)
After reading Crossrulz's reply I understood the logging function you mentioned. Thanks a lot for your help!
Message 14 of 15
(1,931 Views)
Look at this example for ideas, it is part of the shipping examples.
mcduff
Message 15 of 15
(1,913 Views)
