Highlight execution in parallel loops
I am programming an FPGA in Labview, and am trying to debug my code. After switching my execution target to the FPGA's emulator, I activate the "highligh execution button" and press the "step into" button, but the only loop that is stepped into is the first. How can I select which loop's execution do I want to highligh? Thank you.
(3,404 Views)
Could you give more details about what is happening?
I have checked a FPGA example included in LabVIEW called UpDpwn Ctr, Synchronized.vi. This VI has two parallel while loops and when I activate the highlight execution and press step into button several times, the burbles appear in both while loops and the dataflow alternates between both loops.
crisR
(3,404 Views)
Thank you for your answer, but I already solved the problem. I had placed a "stop button" within one of the loops and wired it to that loop's and all the other loop's "stop if true". After deleting that wiring and connecting a local variable of the "stop button" to each loop's "stop if true", the vi started to work properly.
(3,404 Views)
