Histogram question
*see attached VI
 from port 4 (can forget the other ports) the histogram graph,it produces a graph of a 1D array of a cluster of 2 elements. i want a graph of just a cluster of 2 elements, as i've did this throughout the rest of the project, and not the 1D array. any ideas?
(4,041 Views)
Can't see your code because you didn't include generate_hist_Generic.vi.
(4,008 Views)
(4,003 Views)
Accepted by dhanna
In generate_hist_Generic.vi, you've got HIstogram.vi inside a loop, and you're sending the output through an indexing tunnel, which results in an array.
Since your calling vi (hist.vi) passes a single element array, the loop will iterate only one time, and the output will be a single element array.
You can use the Index Array to get the element.  See attachment.
(3,988 Views)
well theres no broke wires anymore, so thats a start!
(3,983 Views)
