HmacSHA1 encryption
How to use labview to encrypt a string with HmacSHA1.
(1,808 Views)
Hi LTYHFA,
You just need to implement your algorithm using all the LabVIEW functions you have available!
(1,771 Views)
There's a SHA1 implementation here (https://forums.ni.com/t5/Community-Documents/SHA-1-Cryptographic-Hash-Function/ta-p/3494144)
You could use that as part of your implementation for Hmac-SHA1 if you wanted?
A description of the process (along with pseudo-text-code) is available on Wikipedia - it looks fairly approachable:
https://en.wikipedia.org/wiki/HMAC
LabVIEW has XOR and comparison functions on the Numeric palette, and so you'd probably just need to be careful with datatypes (I'm guessing the String to Byte Array node might be useful, but I haven't tried).
GCentral
(1,703 Views)
