Ho to move selected files to another directory
What do i have to change in his example that its not recursive but only the selected directory?
Currently it searches in the directory and subdirectory for files that fit to the patternn.
When i use the "List Folder "then i dont have the pattern-selection-thing.
Message 11 of 16
(1,701 Views)
Accepted by OnlyOne
the "List Folder Function" vi should have a pattern input (doesn't show up on context help, look at the full help). This vi outputs an array of strings, you should cast them back to paths using the string to path conversion
.  This version is not recursive.
Message Edited by blawson on 10-20-2009 11:29 AM
-Barrett
CLD
Message 12 of 16
(1,695 Views)
Perfect, now its running as i want.
Thanks to all for the fast help.
Message 13 of 16
(1,690 Views)
hi,
 can u change the version of this program im using labview 8.6 and labview 7.0
N. Srinivasan
Message 14 of 16
(1,662 Views)
Which version do you want?
BTW, it is a simple code, you can do it for/by yourself from this snippet. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
Message 15 of 16
(1,655 Views)
Attached VI is in version 8.0.
Message 16 of 16
(1,651 Views)
