Hoe I can convert a word or sentence into audio output using LabVIEW like the windows narrator?
I am converting Braille script to audio output using LabVIEW. So, I need to convert the script to english and then to audio. How can I do it?
Subash Sainath Gururaj
(3,931 Views)
From what I've seen in my brief search, you need to go the ActiveX route.
Bill
CLD
(Mid-Level minion.)
(3,869 Views)
And I'm guessing that Braille is just a font?
Bill
CLD
(Mid-Level minion.)
(3,863 Views)
Does it have to be Windows?
On OSX, you just run an AppleScipt (from LabVIEW) and use the SAY command (Say "The temperature is 73 degrees").
Steve Bird
Culverson.com
LinkedIn
(3,836 Views)
