07-25-2015 01:57 AM
I am converting Braille script to audio output using LabVIEW. So, I need to convert the script to english and then to audio. How can I do it?
07-25-2015 04:31 AM
From what I've seen in my brief search, you need to go the ActiveX route.
07-25-2015 04:33 AM
And I'm guessing that Braille is just a font?
07-25-2015 05:06 AM
Does it have to be Windows?
On OSX, you just run an AppleScipt (from LabVIEW) and use the SAY command (Say "The temperature is 73 degrees").
07-25-2015 07:34 AM
