Holding Min and Max
I have a VI with multiple T-Couple channels. I got the channels split up and to the array max and min function. How do I hold the highest and lowest values for the entire run? Every time it receives new values(every 5 seconds) the max and min change to the latest data reading.
Thank you
Message 1 of 16
(8,083 Views)
Accepted by topic author Amanda_Kay
Use a shift register to hold the max (or min) value, like this:
Is this what you mean or are you asking about something more complicated?
Message 2 of 16
(8,060 Views)
If you have this running in a while loop that acquires the array of thermocouple readings it should look something like this with the MAX value held on top and the MIN value held below until stopped.  Be sure to preload the MAX with -INF and the MIN with +INF.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 3 of 16
(8,057 Views)
What do you mean by the INF's and what is the function in the middle?
Thank you so much
Message 4 of 16
(8,047 Views)
Try that and look at the output
Spoiler
Max equal +inf And Min -inf Facepalm moment
Use NaN
 The middle function is "Build Array" and it is adding the current max and min the the array to test for max  and min
Message 5 of 16
(8,043 Views)
Thank you so much
Here is what I meant by presetting the MIN & MAX values.  The vi in the middle is supposed to be a representation of all of your thermocouple readings being gathered into an array.
Message 6 of 16
(8,041 Views)
@JÞB wrote:
use NaN
Yes, tried to simplify without looking at the pitfall before me.  Back to the Etch-A-Sketch.
Message 7 of 16
(8,031 Views)
This might be a stupid question but how do I get the positive and negative infinities at the while loop end points?
Message 8 of 16
(8,028 Views)
Nvm, I found it
Message 9 of 16
(8,025 Views)
Amanda,
Like Jeff wrote, you will need to simply create a DBL value and type in NaN (rather than +INF or -INF) by right-mouse-clicking on the shift register at the input to the loop then selecting Create > Constant.  To get the other constants, use the right-mouse-button (RMB) and select NUMERIC under the PROGRAMMING tab to find those options.
Message 10 of 16
(8,023 Views)
