Re: Getting Maximum AND Minimum Value from 1D array on LabVIEW™.
I am having a problems getting the maximum and min value from a 1D array in a while loop on LabVIEW. I have tried different operation but there are not comparable, so am just ask for any help I can get pls. Below is a picture of where am at and the file for my LabVIEW.
(3,670 Views)
I don't recognize the icons you are using -- is that, perhaps, LabVIEW NXG?
I'm guessing that you must be very new to LabVIEW.  When I open the Array Palette (where I expect to find functions related to Arrays), there is one called "Max & Min" that I might think would be appropriate.  I might put it on the Block Diagram, right-click it, and read its Help description ...
Bob Schor
(3,655 Views)
Well, the post was tagged as "LabVIEW NXG".
Back to the OP...
What have you tried?
Since the DAQmx Read is outputting a Waveform, you might need to use Get Waveform Components to extract the Y array and then use the Array Max & Min.
(3,643 Views)
THE MAX AND MIN ARRAY PALETTE  IS NOT COMPATIBLE  WITH IT. I HAVE ALSO TRIED THE WAVEFORM PALETTE BUT IS NOT ALSO WORKING
(3,615 Views)
No need to scream. There is also no need to post the same question in multiple locations.
continued here.
(3,607 Views)
