Hot to create a feedback
So your saying thay i should modify the said program? will putting a flat sequence make the program better? configuring the serial first then the DTR before i could write and read?
CAn you tell me about the handshaking thing and the null modem? im not really familiar about it. thanks
Message 11 of 12
(505 Views)
If you need to put in a flat sequence structure to make things execute in order, yes, do that.  You may not actually need a flat sequence.  Remember that if you wire up the error terminals, that will enforce the order of execution of the different functions and VI's.  All of the serial (configure, read, write) have error terminals, as well as the property nodes.  So if you use them, a flat sequence structure is probably not necessary.
I recommend googling to learn more about hardware handshaking and null modem cables.  The instruction manual for your device should tell you what kind of cable you need, and whether you need to use hardware handshaking
Message 12 of 12
(489 Views)
