How Build a VI that functions like a calculator???
The Front Panel should have digital controls to input two numbers and a digital indicator to display the result of the operation (Add, Subtract, Divide, or Multiply) that the VI performs on the two numbers.  Use a slide control to specify the operation to be performed.
(5,784 Views)
Look, this forums is not a homework service. If you would have searched, you would have found this recent post from one of your classmates.
While you can use the posted VI for ideas, you better modify it enough to make it personal. Remember, your teacher also reads these forums and will know if you simply copy a solution as your own. 🙂
Good luck.
(5,775 Views)
Accepted by edwardty2009
Efforts u make in creating your own work will go a long way, but if u keep cramming, ull always be seeking other persons solutions. I attached a VI but then im sorry i have to remove it. The ethics of this forum do not permit that. Any help on ur genuine work is your rite. But simply copying is not the solution. if u r stuck up sumwhere plz feel free to get help in that regard.
Message Edited by Asad_Tirmizi on 10-26-2009 04:45 AM
Regards
Asad Tirmizi
Design Engineer
Institute of Avionics and Aeronautics
" Its never too late to be, what u want to be"
Using LabVIEW 8.2
(5,732 Views)
Well said.
I would have one small request: Please use full words rather than the Twitter-speak of "u" "ur", etc. Not everyone on this board has English as their first language, so it can be confusing for many people what is being said. Thanks.
(5,701 Views)
Ofcourse Smercurio. Ill try my best to do that. Have a nice day.
Regards
Asad Tirmizi
Design Engineer
Using LabVIEW 8.2
(5,657 Views)
