How Can I clear a multicolumn listbox?
How can I clear a multicolumn listbox (remove all items of it)?
ToNi.
(6,002 Views)
Hello Toni,
Use property node ItemNames, check anex.
Hope it helps,
Paulo
(5,996 Views)
You need to create a property node. Right click on the control or the terminal and select Create>>Property Node.
Select the Item Names property and wire an empty 2D string array into it. You also have a 1D string array for the column headers.
___________________
Try to take over the world!
(5,994 Views)
Thanks. It works 😉
(5,988 Views)
