How Can I load several vi's in the same subpanel?
I want to load several vi's in the same subpanel and I want to have them minimized or maximized, as a MDI Child application. I want to open and load more than one vi's in the same subpanel at the same time. How can I do it?
ToNo.
(3,008 Views)
I can put one vi in the subpanel but not more than one at the same time. Isn't it possible? I want to put my vi's in the subpanel as windows that permit me minimize and maximized this windows (vi's) inside the subpanel as a MDI application.
ToNi.
(2,987 Views)
Can anyone help me please?
I would like to have a subpanel where I could put several vi's inside it with the possibility to maximize and minimze them inside the subpanel. How Can I do it? Or there is the possibility to do it with a kind of activeX control?
ToNi.
(2,963 Views)
Did you follow up on George Zou's suggestion here?
___________________
Try to take over the world!
(2,958 Views)
Yes, but I think you only can minimize one window inside another window but you can not minimize one window inside a subpanel.
ToNi.
(2,952 Views)
Hi ToNi,
reference to create a status bar at the botton of your vi, I´d like to indicate you that you would be able to use Subpanels ( Controls|All Controls|Containers).
Through the Subpanels you can execute differents VIs under execution mode (not at the same time under the same Subpanel, but you can load several subpanels and execute one vi for each subpanel or several vis for each one). You can see some examples in Labview (NI Example Finder and type, under the Search Tab, Subpanel and choose several examples that you´ll find).
Actually, Labview 7.1 cannot support MDI but I´ve heard something about this, and it´s possible under the following version that LabVIEW can support it under enviroment mode.
I hope this helps you
Regards
Diego M
(2,910 Views)
