How I can read-out both inputs from the front and the rear of Keithley199 through GPIB in Labview?
I am reading two voltages simultaneously through the front and back panel inputs of Keithley 199 DMM scanner. How can I have a read-out of these voltages in my Labview program?
(3,296 Views)
Are you sure you can do both?
Read the manual.
On Keithleys I have used in the past there is a pushbutton which chooses which input is active.
(3,279 Views)
I want a read-out of both. The push putton changes the display of the input voltages. My question is whether both can be read simulataneously through GPIB in Labview. Your suggestion/advice is welcome.
(3,267 Views)
Your question should be answered by reading the manual or by asking Keithley. I agree with nyc that the units I have used, the switch enables one at a time.
(3,264 Views)
You are obviously look at the wrong pushbutton.
It is right there on the front panel of the instrument.
(3,262 Views)
Thanks.
(3,260 Views)
My experience with DMMs is that there is a manual switch to tell which terminals to read.  It will only read the front OR the back.  There should be a querry command to programmatically find out which set of terminals it is reading.  I haven't looked at the Keithley 199, but that is how the 2000 behaves.
(3,251 Views)
