How Intuitive Are My Icons?
Can you figure out what these should do just by looking?
Message 1 of 8
(3,265 Views)
UTF to 8, 16, or 32 bit integers, either little endian or big endian.   (How does endianism apply to an 8 bit)?
Convert to ASCII string,
Convert to Unicode.
The pink on pink is a little hard on the eyes.
How'd I do?
Message 2 of 8
(3,256 Views)
That was my first thought, but UTF by itself doesn't mean much (unless UTF-8 is implied). So it could also be interpreted as some string (probably ASCII) to UTF-8, UTF-16 LE, UTF-16 BE. Based on the colour, the output type might be a variant.
Not too sure what UNi does. The red text makes me think it isn't a straight conversion. Perhaps it tests if the input is a valid unicode string?
In any case it's pretty obvious they are some unicode conversion/processing functions.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
Message 3 of 8
(3,201 Views)
  1. Yes, endianness doesn't mean anything for UTF-8 (although it is conceiveable for the multi-byte sequences). That was just a mindless blunder when I was slapping the graphics together.
  2. They are all conversions
  3. Like the built-ins, the inputs are polymorphic (mostly); the icon just shows what it converts to, not what it converts from. So "UTF - 16LE" is what it converts to.  The hyphen and my color choice created confusion there. I'm aiming for a consistent color scheme for this project. The main color being red (well, closer to cerise).  I wanted my functions to all have a matching background color, so I chose pale red. On these conversions, I wanted the text colors to indicate the output type;  but with magenta on pale red, the "BE" and "LE" were very hard to distinguish, so I made them darker.
Ravens Fan: You did well, in the sense that you found deficiencies in my initial icons (which is what I was looking for).
Here's my 2nd whack (though I'm not sure I like the white background):
Message 4 of 8
(3,145 Views)
Hi Paul,
how do you go beyond the 32 pixel limit (height, width) of VI icons?
Message 5 of 8
(3,137 Views)
@GerdW wrote:
Hi Paul,
Those are going to be XNodes, which don't have a limit on icon size; so I don't have to try to squeeze things.
Message 6 of 8
(3,132 Views)
I think I will go with this style:
Message 7 of 8
(3,100 Views)
Yeah that's better, the '-' immidiately bring the mind to to/from.
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(3,078 Views)
