How automatically save excel report?
Dear sir,
I am generated excel report using labview,
Present my doubt is how to Save Automatically that report in specified directory....?
Please Inform me,
Thank you...
Message 1 of 11
(6,224 Views)
I don't have LV with me right now, cause I'm posting on my Blackberry, but I will give you an exmanple on how to do it later on today.
Kind regards,
Bjorn
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
Message 2 of 11
(6,209 Views)
Accepted by topic author NSTL
Are you using report generation toolkit for that?
If so, then you can use "Save report to file.vi". If you are not using toolkit then you can use "Save"  method by calling invoke node
and passing "workbook" reference to it.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 3 of 11
(6,205 Views)
Plz send example as early as possible.....
Thank you.
Message 4 of 11
(6,197 Views)
Thank you,
I tried using report generation toolkit, it is working.......
Thank you once again.
Message 5 of 11
(6,194 Views)
"I don't have LV with me right now, cause I'm posting on my Blackberry, but I will give you an exmanple on how to do it later on today."
Was this solution to your problem?....Smiley Sad
Gaurav k
CLD Certified !!!!!
Message 6 of 11
(6,164 Views)
Sorry,Yesterday i done mistake...your send right solution,
But Before that i pressed Other solution,With out reading your solution,
After i tried For remove that
But it is possible to me...
Thank you Smiley Sad
Message 7 of 11
(6,157 Views)
Please replay this question
How to export wave form data in excel with specified location,
i.e.. Specified column,
How it is possible?
Thank you.
Message 8 of 11
(6,149 Views)
Again report generation toolkit. You can use "Append table to report vi" Here you can decide where to insert data in Excel.
Read Help for same and you will get more information.
Gaurav k
CLD Certified !!!!!
Message 9 of 11
(6,143 Views)
One more thing, I do not have it on my PC, but may you can check if you have Excel specific vis in Report generation toolkit.
Gaurav k
CLD Certified !!!!!
Message 10 of 11
(6,142 Views)
