How build one global VI with several objects?
The Manual says: "You can build several individual global VIs, each with a front panel object, or a global VI with several front panel objects. A global VI with several objects is more effective, since you can group related variables. "
Problem: How can I create a global variable with one front panel and several front panel objects? The manual says nothing about it. Right click on global variable and choose object doesn't help.
Greetings from nuernberg/germany
