How can I Create a exe file were a tab control on it work`s
I have a VI with many controls and indicators,these are spread on a tab control.This tab control works with out any problems but if i create a exe file then the tab control is fixed. How can I create a exe file so that the tab control on it work´s ?"
(3,359 Views)
A screenshot of the front panel doesn't help much. Need to see the VI or a screenshot of the diagram.
(3,359 Views)
It will be good alsa if you can post your project application builder settings, because you say that the problem occures in exe file only.
(3,359 Views)
Make the tab control a control and not an indicator. If you want to write
to it you need to create a local variable.
"Carlos-R." wrote in message
news:5065000000080000005B620000-1031838699000@exchange.ni.com...
(3,359 Views)
Thank`s it worked perfect after I made the changes you sugested.
(3,359 Views)
The Problem was that the Tab control was an indicator and not a control.
(3,359 Views)
