How can I add a time column on my tabular data
The image I attached is a VI Snippet. There's a post about them at the top of the forum board (https://forums.ni.com/t5/LabVIEW/Notice-Attach-VI-Snippets-to-post-rather-than-upload/td-p/3660471) which lists ways to download them in links to that post. Basically, if you download the image, you can drag it from explorer to the block diagram and it will recreate the code.
If it pastes an image, you didn't get it quite right. For me, clicking on the image, the choosing the Download icon to the bottom right edge of the image, then dragging (from Explorer, not the browser toolbar) into the block diagram of a new VI works (it doesn't have to be a new VI either - you can drag snippets into existing code if you want to).
GCentral
Message 41 of 59
(1,057 Views)
@Zaqf wrote:
Would be great if you could attach as vi.
It would be nicer if you did just a tiny bit of your own work yourself.  It should take you less than 10 minutes to duplicate the code on your own PC, and as you do it, you could think "Why am I using a For loop?", "What does this Build Array function do for me?", "How does this Write Delimited Spreadsheet function work?", and "What do the inputs in Write Delimited Spreadsheet mean?".  For some of the answers, you may need to right-click the function and choose "Help" from the Drop Down menu, then read the Detailed Help.  This is part of Learning LabVIEW, which requires some work on your part ...
Message 42 of 59
(1,056 Views)
Thank you so much.  Unfortunately , I'm not in the place to work on labview so I'm trying to find answers to all the problems I might find , when I work on it tomorrow .  So I could attach a waveform chart to the connection to the array , yeah ?
 Thank you so much. Would be great if I could get your email. I'm so debted to your service for my case. 🙏
Message 43 of 59
(1,045 Views)
I deeply respect your concern for my growth and I thank you. But for now I'm in a position to complete the project I've been assigned. Definitely, I ll try to do this from scratch.
Expecting your faithful service .
 Thank you.
Message 44 of 59
(1,044 Views)
Re the first point (LabVIEW availability) you should check with your IT department / licence holder - I think since 2017 the Academic Site Licence (which you may or may not have) covers use on personal computers owned by researchers. Looking at the link here: http://www.ni.com/en-gb/shop/academic-site-license.html suggests that benefit extends also to students.
Re the waveform chart - yes, it's possible. In the case of my snippet, you don't want to tick the Transpose Array (right click on the chart), but you should note that in my example the time resets to 0->0.1s every time, so the time array is odd. Typically you'd just add the values for a waveform chart (so a 1D, not 2D array) and then change the X-axis scaling (under properties, you can also use a Property Node, but that's a bit beyond this topic). Google can probably help you find those if you're wanting to do that. Your input may be significantly different to mine (depending on how you're generating it) so you may have a slightly different experience.
If the final point was addressed to me, I don't typically (or indeed, ever, as far as I'm aware) give out my personal email address on public websites, but it's possible to message forum users by their usernames.
GCentral
Message 45 of 59
(1,039 Views)
It's getting pasted as an image.  And which is the function to tabulate the array ?
Message 46 of 59
(1,025 Views)
Probably need some more details, but if you follow the instructions I gave a couple of posts ago it should work. Make sure you download the image - dragging it from the website won't work.
I think you're talking about the Write Delimited Spreadsheet function. If not, then perhaps you can describe what you're looking for in more detail. The VIs/Nodes used were just:
  • Random Number, Multiply
  • Build Array
  • Write Delimited Spreadsheet
GCentral
Message 47 of 59
(1,021 Views)
I started it from scratch. I've got two data values , so should I make it a 3d array?  The write to spreadsheet is not working , as in I tried to copy the data to excel as well as .dat file(notepad). Both aren't working for me.   Could you please attach as vi
Message 48 of 59
(1,018 Views)
I expect you want a 2D array, where each row is a 1D array of either times or values.
You might want a time array for each value array, or they might share a time array.
Be careful if they don't have the same sampling rate - you'd need to use clusters in that case (because you can't have different length rows in a 2D array).
If you attach a new copy of your VI (that can be opened in 2017) I can take a look at it.
GCentral
Message 49 of 59
(1,016 Views)
1 sample hw timed with 4hz. Actually with two data . Tried to build array , then tried to build matrix , but could save the data in both cases. After figuring this issue , I need to add a waveform graph as well.  Filepatg I've tried in .dat file as well as xlsx. , Not saving the data in both
Message 50 of 59
(1,013 Views)
