How can I automatically close a PDF document after it is done printing?
Hello all,
To cut to the chase I am using the System Exec.VI to open a PDF with Adobe Reader 8.0 and printing the document.  I can do this without a problem.  The problem is I would like to have this window close automatically when it is done printing.  I have seen on the web that the switch to make this happen is /t, but for some reason my pdf doc is not closing.  My command line looks like this
"C:\Program Files\Adobe\Reader 8.0\Reader\AcroRd32.exe" /t  "path to the file" "default printer name"
Is there another way to terminate the window not using switches in the command line statement?
I have tried using active x calls to open the doc and print but I am not seeing any print options in the active x calls.  I have searched thourgh a large portion of the classes and could not find any print statements.  I have also tried opening the doc with the system exec.vi and priting and then closing it with active x but I get an error message back.
Has anyone had any success in opening a pdf doc, printing and then closing the window automatically afterwards?
(6,511 Views)
Hi gammalight,
i use Adobe Reader 7.0 and it works in this way for me. The document is printed with the default printer.
Mike
Message Edited by MikeS81 on 03-28-2008 04:26 PM
(6,507 Views)
Hey Mike,
Thanks for the reply, but I tried it exactly as you have it but for some reason it still does not work.  I can not even get my window to minimize, i.e. having the true constant wired into the run miminized option.  Again I am using Adobe 8.0.  Has anyone using Adobe 8.0 had this problem, or knows how to fix this problem?
gamma
(6,493 Views)
Hai,
Better you can use open file.vi to open pdf and user32.dll functions to generate mouse click events on the appropriate positions you require.
Mathan
(6,436 Views)
