How can I block a control?
I have a control and I wish sometimes blocks it.
Block for me is: You can't insert data.
How can i do it?
Thanks.
(2,950 Views)
Hello Carlos
Create a property node for that control
Selec disable and wire a constant "2". That will dim the control and no value can be written.
Wire a "0" to enable it back.
Se attached doc
Hope it helps
Alipio
"Qod natura non dat, Salmantica non praestat"
(2,950 Views)
put your vi or control in a true "case structure", case true you record,
case false nothing so no record
I Hope this answers to your question
Gérard
Gérard Férini
Switzerland
http://home.tiscalinet.ch/gferini
http://www.pbase.com/ferini
remove -move to reply
ferini@move-bluewin.ch
"Carlos Romero" wrote in message
news:506500000008000000C0FC0000-1079395200000@exchange.ni.com...
How can i do it?
Thanks.
(2,950 Views)
Gérard
Gérard Férini
Switzerland
How can i do it?
Thanks.
(2,950 Views)
