Resizing FrontPanels
i have Front Panel with TabControl on it. when user Resizes the panel only TabControl Should get resized with whatever is there on tabcontrol and objects outside TabControl should not get Resized. how can i achieve this
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
(3,087 Views)
Try going to file/VI properties/window size and check the box for scale front panel objects as window resizes.I'm just taking a guess here because I cannot open your Vi since I do not have version 7.1.
Hope this helps
Joe
Joe.
"NOTHING IS EVER EASY"
(3,087 Views)
Hello Tushar,
Currently LabVIEW does not support the ability to scale a tab control and its contents without scaling all front panel objects. However, we can work around this by creating our own tab control. Attached is small example of how this is accomplished. It works by combining a tab control with a raised box decoration. It then hides and shows the correct contents depending on the tab currently selected.
Matt F
(3,087 Views)
thanks a lot Matt F. this idea really works...
Tushar Jambhekar
(3,087 Views)
