How can I build a timestamp?
I have files that have been given filenames that include the year, month, day, hour, min, sec, msec that they were created. The filenames were generated from a timestamp and a format string, I need the inverse function. How can I recreate the original timestamp with a format string and the values I have available.
I've tried numerically computing the timestamp with the number to timestamp VI, however I can't figure out how labview handles leap years/seconds or some other unknown factor that prohibits me from regenerating the original timestamp.
(5,180 Views)
You need to use Scan From String to get the various parts and then wire that data to the input cluster of Date/Time to Seconds. The attached example shows this. If the structure of your filename is different, you can simply change the format string to match what you have.
(5,180 Views)
thanks, I had assumed the date/time to timestamp VI took a timestamp as an input since it was a similar brown wire going in, and had been cursing NI all day for not providing such a VI =D much much simpler than trying to numerically compute it
(5,180 Views)
