LabVIEW will stop loading at the splash screen if there is an incorrect setting in the LabVIEW.ini file located in your C:\Program Files\National Instruments\LabVIEW x directory. The LabVIEW.ini file contains many of the LabVIEW settings and preferences and is automatically written to when LabVIEW runs.
My suspicion as to why LabVIEW is crashing at the Server: Exported VIs... message is because the last time LabVIEW was running, the option to select the list of Exported VIs in Tools >> Options >> VI Server: Exported VIs was changed to a setting that LabVIEW did not agree with. Go ahead and browse to the LabVIEW.ini file. Probably towards the bottom of that file, you'll see the key "server.vi.access". By default, this key has the setting "serve
r.vi.access="+*". You can try changing this setting back to its default value or just remove that line entirely. Once the LabVIEW.ini file is changed, then try relaunching LabVIEW. LabVIEW should hopefully work at this point.
Note that editing the LabVIEW.ini file is only recommended for advanced users or to users in situations where LabVIEW is not launching correctly. Editing the LabVIEW.ini file without knowing the proper keys/values may cause LabVIEW to crash. However, for information regarding some of the other LabVIEW.ini file settings, you can refer to
Brian Renken's LabVIEW page.
Have fun and be careful!
🙂Kileen C.
