How can I call EXE from LabVIEW ?
I want to call an EXE file from LabVIEW "directly" without any DLL wrapper. How do I do it?
(3,931 Views)
I believe the VI that you are looking for is the System Exec.VI. The VI is located on the communications palette. This VI will allow you to execute a system command such as notepad.exe or some other executable file.
Heath
(3,931 Views)
Thank you for help. I found it in place where you
mentioned.
Thanks.
(3,931 Views)
mentioned.
Thanks.
(3,931 Views)
The node is called System Exec and it is in the Application Control
palette I think -- with the VI Server Functions. You basically give a
command line and some options for synchronization, etc.
Greg McKaskle
(3,931 Views)
Thank you Kreg. I found it in 'communication'.
Thanks for help.
(3,931 Views)
