Why is the Analog Input data incorrect when VI is restarted?
In the attached Read Temp.vi I get correct data the first time it is run. Once stopped and then restarted the data values are incorrect. If I remove TS-1 from the I/O channel list then correct data is reported even when rerun. Why do I get incorrect data when I rerun and have TS-1 in the I/O channel list?
(2,763 Views)
Which version of NI-DAQ are you using. try to upgrade it to version 6.9.2 available free from National Instruments website and see if it helps. It should.
Please tell me if it does not help.
Sincerely,
Sastry V
(2,763 Views)
I installed NI-DAQ version 6.9.2 from the upgrade CD distributed in Feb. 2002. The system responds as before, the program continues to behave incorrectly.
(2,763 Views)
