Doug,
I don't think you can do this with only the base package.
If you had the Graphics Format VIs, you could use the VI Server VIs and the Get Panel Image to get the image of the front panel, and then save it as bmp, jpeg, or png file.
If you had the Report Generation Toolkit, you could add this image to the Word Report, and save it as a Word Document.
Upgrade AdvisorZvezdana S.
