How do I set the paper size to A4 when using report Vis
When using the report Vis they seem to default to letter size paper despite the printer defaults being set to A4. When printing panels etc. from the menu the paper size is selected correctly as A4. Operating system is NT
(3,682 Views)
To change the paper size of a Word document, you would need to modify the Word_Print.vi, under \vi.lib\addons\_office\_wordsub.llb, and add the PaperSize property for the document.
Please find the attached example, for LabVIEW 6.1, that has this property added.
Zvezdana S.
(3,682 Views)
