How can I change the default path for the user defined error files in LabVIEW
I would like to share user defined errors over diffrent platforms (LabVIEW for Windows & Linux).
In LabVIEW for Windows, I can change the default path to the user definded errors by entering:
UserDefinedErrorsDir=Q:\LabVIEW\SW\Libaries\
into the LabVIEW.ini file.
Then I only have to copy or edit all my ...-error.txt files in the directory:
Q:\LabVIEW\SW\Libaries\errors\
I know, that for LabVIEW for Linux I have to edit the .labviewrc file.
But what do I have to enter?
UserDefinedErrorsDir : wsw/LabVIEW/SW/Libaries/
(You know our Windows Q: directory is in Linux the wsw path)
Do I need an absolut path, a relative path or whatever?
(2,976 Views)
You have to write into the .labviewrc file the following line:
labview.UserDefinedErrorsDir: ""
'' ist the absolute path where your errors-directory is saved (eg '' is '/wsw/LabVIEW/SW/Libaries/').
(2,976 Views)
is "UserDefinedErrorsDir" is a feature of LV 6.0 only?  I'm on 7.1 and this is not working at all.
I tried UserDefinedErrorsDir=C:\
UserDefinedErrorsDir="C:\"
UserDefinedErrorsDir="C:"
and nothing works.  Of course I put my own "*-errors.txt" file in c:\
any idea?
thanks
Éric
(2,866 Views)
Hello Eric
I am using the "UserDefinedErrorsDir" in LabVIEW 7.1 /7.1.1 Windows and Linux.
But there is a "syntax" problem. Let me explain this:
If you enter
into your LabVIEW.ini File, LabVIEW will not search the Files in your C:\      Directory...
LabVIEW search the *-errors.txt Files in the
C:\errors\
Directory!
That mean that you have to create a folder with the name errors in your
UserDefinedErrorsDir and after that you only have to copy all your *-errors.txt Files into this folder.
Happy Wiring
Martin CLAD
(2,834 Views)
