How can i remember array, a using after next time in graph plot
Hello i have a two graph , first graph case 'AF' consist with 3 arrays a second graph case 'BF' consist with 3 arrays + i need arrays of case 'AF', how can i do it? I have attached example.
(3,818 Views)
If i have understood you right, you want to save the AF graph plots.
am i right? if not plz correct me.
If i got u right, the simplest is to build a 2 D array by merging your 1D arrays and write to spreadsheeet file.
Now, you can read it whenever u want and display on the XY graph.
hope this help, if not, plz eloberate on what you are looking for.
Regards
Dev
(3,812 Views)
Hello, i do not underestand you, can you give me a example<
(3,809 Views)
i want to save AF+BF value to the text file , periodicaly and i want to plot graph AF+BF together.
(3,807 Views)
One small clarification i seek
Case AF displays 3 plots
Case BF displays 3 plots
so what you want to do is to plot all these 6 plots on same graph????
Plus you want to save these 6 plots in a single file
Do i understand u right?
(3,802 Views)
Hello i solved the problem, it is easy, i am using Local variable and this variable enter to the array of graph 2
Thank
(3,802 Views)
cool!
good going!
(3,799 Views)
