How can I change the mnu file path?
Hello All...
I'v download driver from NI site and I put It in some directory, howevere when I put the dir.mnu file in the tool pallete all the driver sub VI's became "?".
Now my question is how can I edit and change the dir.mnu file path so the sub menu and VI's will be loaded correctly.
ErezB
(2,949 Views)
Hi Erez,
The mnu file should reside in the same folder as the llb files that contain those VIs. Make sure that it resides in the folder with those llbs and you should be ok.
Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(2,930 Views)
