Hello Everyone!
I am developing an application which will use a PDA and a barcode scanner. I would like to be able to have the operator scan an item & proceed to the next test step w/out the operator having to push an "OK" button on the PDA screen.
The barcode scanner sends data to the string control just like the keyboard does while typing keys - (I think keyboard wedge is the proper terminology). Since the PDA module does not provide the update while typing property node I am not sure how to get the string control to update the vi without some user interaction. Currently I am giving the string control key focus & the barcode scan is sent to the control correctly but the only way to get the control to update is to touch anywhere on the PDA screen (take focus away from the string control). I have tried some of the examples on the forum which use the carriage return sent from the scanner & key navigation to toggle an ok button but this also does not appear to work with the PDA. The example I have posted is looking for a ":" which is sent as the last character from the scanner to determine if the scanner has sent data. I just can't find a way to have the program take focus away from the string control so that touching the PDA screen would not be necessary.
I know that there are many Labview experts on this forum & I hope there is a workable solution to this problem!
Thanks In Advance For Your Help,
Bob
