How can I change the sample rate (delta X)?
Hi, I create vi which can measure resistance, it will record the data and write to a file.
however, I want to change the sample rate which is delta x. is that anyway I can do?
I have try to put a clock inside the loop, it does slow down the speed but not the sampling rate.
Please help me!!
Thank you!
(2,747 Views)
Sorry, I forget to attach the picture.
(2,746 Views)
Hello Shan405,
Adjusting the Reading Rate of a DMM
As noted in the above DeveloperZone article, there are a lot of factors contributing to a reading rate of a DMM. 'Sampling rate' can only be configured in digitizer mode, which can only be achieved on the flex DMMs
Using the NI PXI-407x DMM as an Isolated Digitizer
Glenn
(2,696 Views)
