How can I check to see if a shared variable library is deployed?
I have shared variable libraries I am deploying in my executables. How can I check to see if a library is already deployed or not being that I do not want to re-deploy if not necessary?
(4,734 Views)
Trosier-
The DSC module exposes that functionality for you in a VI called Get Process List. If you do not have the DSC module, you can attempt a read on a shared variable and look for error -1950679035 which indicates that the library has not been deployed and then deploy it if you choose.
Xaq
(4,720 Views)
