pda read text file
Hi,  i can't seem to read the text file on my pda correctly though i can do perfectly ok on the PC. Please help !
Lance
(9,198 Views)
m3mories-
I have found that it is better to use the auto dialog from teh open file on a PDA rather than the manual dialog. Try removing the file dialog VI.
What about th eread is not working? Do you see any output from the Data string?
Xaq
(9,158 Views)
Hi Xaq, i have removed the file dialog VI but it still can't read out the data
(9,112 Views)
Hey
You need to describe what is happening on your PDA when you run your application.
If you are running the example you have posted, it seems like the application would close as soon as the data was displayed on the graph.
A PDA application does not work the same way as a PC application.
Good Luck
Eric
(9,001 Views)
