You must have the VIs on your PC, and when you switch execution target to the RT side running your EXE, it will ask for the front panels for the VIs in memory. Once you point it to the front panels, you should be able to stop the VI like you would in the development system, typically with a stop button on the front panel, or (generally not recommended) with the abort button in the toolbar.
