How can I communicate between two simulated software
Hallo,
I have confusion regarding this topic "How can I communicate between two simulated software".
1: PC with CAN simulation
2:  PC with AFDX Simulation
Now i have to communicated these two pc with each other.
How can i communicated? which module from ni is best for it.
thanks in advance
BR
(3,011 Views)
Hi BR,
communication between two PCs is usually done using some kind of network protocol - you can use anything from UDP to network streams…
(3,009 Views)
thank for quick response, but, could you please explain a bit more.
Since I am not so familar with network protocol. it would be great if you give some INFO.
BR
(3,005 Views)
I recommend looking at the Simple Messaging Reference Library that NI has released.  Use the TCP/IP version of it.
FYI, TCP/IP is a communication protocol that is used to communicate between two computers.  It is what the internet uses.  So you just need a network switch or router between your computers and you can talk to each other with their IP address.
(2,995 Views)
