find maximum value value and uppdate continously in the panel
I meassure force using a load cell. All meassurements are stored and I need to compare the current value to the stored maximum. The all-time maximum value should be presented i front panel.
How do I find the maximum value?
Message Edited by Johan.svensson on 06-26-2006 02:22 AM
(8,900 Views)
Just compare the value with the previous max (from a shift register) using Max&Min, then feed the new max to the shift register. Repeat.
See attached image of a code fragment.
Of course a final program would need logic to reset the max, etc.
Message Edited by altenbach on 06-26-2006 12:35 AM
(8,895 Views)
Thanks!
very helpful
(8,875 Views)
Thanks a lot.
(5,675 Views)
