How can I compile my VI's from remote target?
Hello all... 🙂
While compiling my FPGA VI's the following error occurred... Is it possible that I can compile my VI's from remote target that is on same network....? Please reply...
ERROR:Portability:3 - This Xilinx application has run out of memory or has
encountered a memory conflict. Current memory usage is 2094816 kb. Memory
problems may require a simple increase in available system memory, or
possibly a fix to the software or a special workaround. To troubleshoot or
remedy the problem, first: Try increasing your system's RAM. Alternatively,
you may try increasing your system's virtual memory or swap space. If this
does not fix the problem, please try the following: Search the Answers
Database at support.xilinx.com to locate information on this error message.
If neither of the above resources produces an available solution, please use
Web Support to open a case with Xilinx Technical Support off of
support.xilinx.com. As it is likely that this may be an unforeseen problem,
please be prepared to submit relevant design files if necessary. "
 Thanks for any help from you... 🙂
(2,976 Views)
Accepted by topic author Rupali
Yes you can compile your FPGA VI on a remote machine on the same network.
You can follow this help to dig further.
Have a good day.
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
(2,929 Views)
