How do I express special characters such as [EOT] in labview? ('\x04' inC)
(3,648 Views)
Go to the help in the toolbar, then select the search the LABVIEW help, type strings in the search field. You can also use the Ctrl+? shortcut.
Good luck
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,637 Views)
Right click on a string control or indicator, select '\ display', this will show special characters with a \-formatter. For EOT use \04:
Ton
Message Edited by TonP on 03-02-2009 02:16 PM
My LabVIEW Ideas
(3,622 Views)
