How can I configure NI PCI 6221 and DAQ SCB-68 for pressure sensors?
Hello everybody,
I am using the measuring board (NI PCI 6221) and DAQ SCB-68 for the data acquisition.
With the DAQ-Assistant I created AI for the voltage of pressure sensors. In a big indicator panel from this DAQ-Assistant I see the voltage for both sensors in the correct size. But if I set sensors in the blockdiagramm to control the signals for sensor one I get a wrong voltage size and for sensor 2 nothing.
How can I configure this data acquisition equipment to get the correct signals?
Thanks a lot for your help.
(2,691 Views)
I do not know the type of sensor you are using. But pressure transducers may have a very low output voltage(in the mVolt range). They also need an excitation voltage. Here is an introduction.
http://focus.ti.com.cn/cn/lit/an/sloa034/sloa034.pdf
Then working with pressure sensors I always use 3 stages in the circuit.
1 Instrumentation Amplifier as a preamp
2 filterstage
3 Final amp and output buffer
(you may combine stage 2 and 3)
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,680 Views)
Maybe that is the solution. I will try and reply.
(2,667 Views)
