How can I control a HP 33120A waveform generator with the serial port of my PC?
I want to control a HP 33120A waveform generator with my PC using the serial port. I don't have any idea about how to do it. If you've done it or if you know how I can do it, please give me some indications.
Jean-Baptiste Paillet
PS: I don`t have G PIB port
(3,705 Views)
Although I've not used it there is an instrument driver for your instrument on NI's site that says it supports serial communication. That may be a good start.
This should take you there:
http://zone.ni.com/idnet97.nsf/9b2b33e1993d877786256436006ec498/fdfa63edb4a238bd862568ab005fbd39?OpenDocument
Hope this helps!
Brian
(3,705 Views)
You will need to set the interface on the instrument for RS232 use. I think by default it maybe set to GPIB.
Make sure you download the IVI version of the driver. The non IVI are GPIB Only.
You will need to setup the Measurement and Explorer.
Regards
Ray
Regards
Ray Farmer
(3,705 Views)
