How can I control a driver using Matlab?
For a lab project I have to program in matlab a driver (esp300 by Newport - http://www.newport.com/store/product.aspx?id=3229) that commands a motorized stage of the same company. The interface is GPIB. I rather control the driver using only matlab, but if i can't - i wan't to use Labview as a connector between the two. any idea how can i do one of the above? I've got no idea where to start from. I'll thank to any given advise.
Message 1 of 8
(5,172 Views)
Is there a reason that you aren't doing the entire project in LV?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(5,166 Views)
A google search on "matlab instrument gpib" will probably be helpful...
-Rob
Rob Purser
Manager, Test and Measurement
MathWorks
rob.purser@mathworks.com
Message 3 of 8
(5,155 Views)
The reason I'm not doing everything in Labview is because i have to get data and analyse it, and i prefer to do it all in the same program
Message 4 of 8
(5,153 Views)
Hi avenger,
"because i have to get data and analyse it, and i prefer to do it all in the same program"
Yes - where's the problem in using LabView?
Message 5 of 8
(5,145 Views)
What is the analysis that ou need to perform. The resources that are available to you from within LV is very complete!
Mike...
LabVIEW Champion
Message 6 of 8
(5,134 Views)
well, i'v checked this option, but unfortunately i couldn't get the software (LV), so i'm back at square 1.
Message 7 of 8
(5,086 Views)
I would again suggest a google search on "matlab instrument gpib"...
-Rob
Rob Purser
MathWorks
Message 8 of 8
(5,082 Views)
