Plotting Motion Table Positions with LabVIEW
I have an X-Y motion control system and a radial table mounted on the X-axis. With LabVIEW,
can you add "slider" bars that show the position of the X-Y tables? What about a circle with an arrow to show the position of the theta table? I am not sure what graphing function or combination of functions I should use.
Thank you for your help. It is greatly appreciated.
Kyle
College of Aerospace Engineering
Georgia Institute of Technology
(3,087 Views)
There are many ways to show positions, points, and graphs in LabVIEW.  What you need depends on what you are trying to do, and what data you are working with.  You want to "show the position of the X-Y tables"; what type of data are the X-Y tables that are coming in?  Are they tables of data that have x values and y values?  And what type of data is the "theta table"?  I think a clear explanation of what you would like to do is the first step.  I don't quite understand the "slider bars" and "position of the X-Y tables".
reggier
(3,069 Views)
