How can I control de window menu?
I need to control de itens in the window menu that are controlled automatically by LabView. How can I do that?
(3,362 Views)
Window Options are obtainable by right-clicking on your VI Icon in the upper-right corner of your Front Panel, then selecting VI Setup..., then selecting Window Options from the drop-down menu. Set your options as needed. Good Luck - Doug
(3,362 Views)
I fact a need more flexibility to control the windows names inside the window menu of the application
(3,362 Views)
Before you rate one's answer so lowly, make sure your question is clear enough to begin with. Hope you find what your looking for!
(3,362 Views)
If i got the right sense of your question, you can control menus using the functions under Application control>>Menu.
Hope this helps
(3,362 Views)
If I understood correctly what you ment by your question, I attached an example showing how to use the Labview menu control VIs.
Regards
Filipe Altoe
Application Engineer
(3,362 Views)
