How can I controll my burstgenerator via the HostVI?
Hallo,
I build a new digital Burstgenerator. The generator works on the car 7833R. The fpgaVIs are ok, but my controll from the host.VI doesn't work. What is my problem? What can i change? It would be nice, if somebodoy can look at my code an help me.
Martin
(2,965 Views)
It would be very helpfull if you either explain your EXACT problem or better if you try to narrow down the code to a part which is easy to understand and shows your problem.
Christian
(2,943 Views)
I can't narrow my code, because I don't know in which part ist my problem. My Problem is that I can't controll my send_burst.vi form the host Vi. I don't receive Bursts on the scope. I think the FPGA run but the start is not set true. I need especially help to read the parameters first an then send to the fpga and start it.
(2,941 Views)
Accepted by ernstm
Starting/Stopping FPGA VIs from the Host, reading/writing parameters, so frontpanel objects are very basic things which you will find in the most fpga example projects in LabVIEW. I really would suggest you to have a look at them.
(2,939 Views)
Hallo,
sorry that I need more help. I looked at examples and I can't find my problem. I want that if I press start the send_burst.vi should run till i is >= N Burst.  I tried to do this with a case-structure but it doesn't run well. I can't see any pulse on the Output. If I run the main_burstgen(HOST)  some pules come out automatically. What did I weong?
I hope you can help me.
Martin
(2,919 Views)
