How can I create a LabView driver with existing driver vi's?
I am trying to create a 1553 driver for LabView. I received all of previously created 1553 LabView driver files from the manufacturer. I have also used Tools->Instrumentation->Create Instrument Driver Project to start a new project. I used a new template and the block now shows up under Instrument I/O. I moved all the previously created 1553 driver files to the data folder in the project located at C:\Program File\National Instruments\LabVIEW 8.6\1553Data\Public\Data.  I don't see any of the driver vi's available under the Instrument I/O->1553Data. How can I make these vi's available for use?
I am also unsure of which folders my files should go in (Configure, Data, Utility, etc.).
Thank you.
Message 1 of 8
(3,430 Views)
"atcooper" <x@no.email> wrote in message
news:1234465816735-852236@exchange.ni.com...
> I moved all the previously created 1553 driver files to&nbsp;the data
Instruments\LabVIEW 8.6\1553Data\Public\Data. &nbsp
If you want them in your palette, you need to put them under the instr.lib
directory: C:\Program File\National
Instruments\LabVIEW 8.6\instr.lib\1553Data\Public\Data
Utility, etc.). &nbsp;Thank you.
VI's that are used for configuration of your device go under Configure.
VI's that are used for reading or writing data to or from your device go
under Data.
VI's that are convenient, but don't fall into the other caragories, under
Utility.
Wiebe.
Message 2 of 8
(3,408 Views)
I have moved my files to the location you have listed and have opened up some of the Read vi's to make sure all their dependencies are properly linked. I still don't see their icons under Instrument I/O->Instr Drivers->1553Data->Data.
Did I do something incorrectly when creating the driver project?
Thank you.
Message 3 of 8
(3,398 Views)
news:1234530617176-852726@exchange.ni.com...
linked. I still don't see their icons under Instrument I/O-&gt;Instr
Drivers-&gt;1553Data-&gt;Data. &nbsp;Did I do something incorrectly when
creating the driver project? &nbsp;Thank you.
Did you restart LabVIEW?
Wiebe.
Message 4 of 8
(3,385 Views)
Yes, I have tried a few times and the computer was shut down overnight, so everything got restarted.
Do you think there could be something in the vi's themselves keeping them from displaying? They all have icons, but maybe there is a setting that I don't know about to have them show in the menu.
Thanks again.
Message 5 of 8
(3,383 Views)
All the directories in instr.lib should show up in your palette. But I
checked, they are under Instrument I/O>Instr Drivers>, not directly under
Instrument I/O.
You should not have to do anything special.
Wiebe.
Message 6 of 8
(3,373 Views)
Accepted by atcooper
I figured it out. Here is how you insert the vi's into the palet:
Tools->Advanced->Edit Palette Set
I went into the data section and right clicked. There is an option to insert vi's. I clicked this and picked my vi to insert and now it shows up.
Thanks for you help.
Message 7 of 8
(3,368 Views)
news:1234537821842-852850@exchange.ni.com...
palet:&nbsp;Tools-&gt;Advanced-&gt;Edit Palette Set&nbsp;I went into the
this and picked my vi to insert and now it shows up. &nbsp;Thanks for you
help.
You shouldn't have to do that... It should insert instr.lib vi's
automatically.
Anyway, have a nice weekend.
Wiebe.
Message 8 of 8
(3,351 Views)
