How can I create an application that has no menu bar?
I have an application which has all of its functionailty available on screen as buttons or fields. This works very well at the moment. However when I create and run the application I see a men bar appears nuch the same as when deisgning the application namely, "File, Edit, Operate, Tools,, Browse, Windows, Help". I really don't want them to appear at all as everything is already catered for on screen. I have looked at the menu vi's but it is not clear how I can simply not have a menu bar.
Any suggestions?
Regards
Kevin
(2,590 Views)
Look at the options in File>>VI Properties>>Window Appearance>>Customize.
___________________
Try to take over the world!
(2,584 Views)
Many thanks,
I have asked a similar question to this before but for some reason I always think I need to do these sort of things programmatically in the code rather than in a settings.
Thanks in any case.
regards
Kevin
(2,572 Views)
